  #25
Old 06-04-2012, 12:55 PM
Cool ??
Originally Posted by Scott Pope View Post
Ken, I didn't mean to be off topic. Your main question: the difference in feel between the 3/4 and the 4/4 Spiro mittels: according to the numbers, the 3/4 3885 set, on a @106 cm mensure bass, compared to the 4/4 S42 set strung on the same bass, might feel a little bit stiffer, but hardly noticable, assuming the bass is setup with the proper overlength to the tailpiece, and the pegbox geometry being able accomodate either string.
I only posted the numbers to get a broader perspective, and to remind everyone about all the current different choices now available for Spiros.
Thank you very, very much for the history of the reverse stagger tuners. I've also swapped out which string goes to which tuner to lessen the stress on the E string break over the nut and to better seat the G string to avoid "twang" as well.
I thought the main question was the Bowing of the Reds in Orchestra. The tension between 3/4 or 4/4 sets do not matter all that much. Why would one buy strings too long or short for his bass? Plus, each bass has different tensions as well so I am not really concerned with the String numbers as the bass and its set-up will matter more.
Also, I am glad to see you had some positive results moving the strings to different gears. I also think it helps to open up the sound a bit when lengthening the E-string up to the A-string Post.
