Hi guys, this is a thread I started on TB back in 2004. Since I am here now, I thought I would copy my own basic text of it over to here and if anyone feels up to it, continue on. If not, at least we have it here for reference. I have brought the text up to present time as many did make guesses in this 6 page thread but I don't think I am allowed to copy anyone else's replies over to here. I will sum up the findings so we can go on from there if you're in the mood.
------------------------------------------------------------------------- I got this Bass back in Feb, 2004. It has many flavors from all that have touched it. In March of '04 it went out for a full restoration and reconstruction. I am expecting it some time this year (2007) Members are welcome to post their ideas as well. Ask questions if you like as to what I might have seen inside that I can't show here or whatever. Here is the the link posted on my 'site; http://www.kensmithbasses.com/doublebasses/MysteryBass/name_that_bass2.htm ('Before' pics linked from there as well) Let's have some fun with this old relic...... A major restoration was done around 1850 or so give or take 25 years. The Bass was old then ! The angle taper of the Back may not be original and could have been done later. This Bass was also slightly bigger from what I can see. The Purfling on the Top runs out on each of the 6 Bouts as if it was 'greatly' worn from use and abuse or was slightly cut or trimmed about 5mm or less on each Bout. Maybe the Back shrunk and the Ribs were shortened. The extreme curl of the Sycamore could have made the Bass shrink more than usual. The Back however is not Purfled on the edges but rather has a faint hint of painted Purfling around all edges which runs out as well. The Back also has a thin Ebony strip inlaid down the center Seam which leads me to believe it was added later to fill the gap from shrinkage. Who might have used such fine grade flamed sycamore for the back (28" wide,2 piece) and ribs or the tight grained Quartersawn Spruce with 350 growth rings within 14" of width (x2=28"wide) ?? Who could have demanded this top grade of wood way back then for a Bass when it could have made at least 6 fine Violins? This Bass has had many repairs and modifications over it's long life. The Varnish is original under the repairs except for some touch-up with a reddish tint. The F holes are original and the Neck Block taper seems to be original as the Purfling is still there on the Top. The gentle lower Bout cut is original as well and this and the other features might help find it's origin. Of course when the Top came off and we examined the Blocks, old Cross Bar Scars and Linings, we were able to figure out some additional possibilities. By the way, the flames of the Back and Ribs are twice as intense from the inside where there is no Varnish obscuring the figure. The wood is very dark on the inside indicating the Bass is quite old. I can pick it up easily in one hand despite its size as the old dry wood is beyond seasoned! The total height of the actual Bass (without endpin) is 77" tall (6ft.5in.). It was probably an 'Eb' Neck and will be reduced to a 'D' Neck ending up around 76" or so after the new Neck graft. It is more likely we will find the period and origin before the maker, if at all. It would be great if we can always find the maker but with Basses not always being the main product of the shop as well as the Master/Apprentice situations in many shops, it is often that the Bass was made by other than the 'head honcho'. Therefore the makers hand is not always evident. Just to clarify things, the work is being done by my long time friend and Luthier Paul Biase in NY. Other than Peter Eibert, he is my oldest acquaintance in this field and from the old school. I had just met Arnold and Jeff on line at TB shortly before I bought this Bass. Had it been a year later, I might have given the Job to one of them if they would have accepted it. I am glad Paul is taking his time on this. The buckled Ribs are very flat now in comparison as he has spent a lot of time fixing them. Here are the pics of the Cheeks I made 3 years ago. The Cheeks will get thinned down slightly before the Varnish touch-up.
| Currently Active Users Viewing This Thread: 25 (0 members and 25 guests) | |
