Old 01-04-2010, 03:39 PM
dayan tejada dayan tejada is offline
dayan tejada is on a distinguished road
Question bsr6m info ?
thanks. it is posible have any info about this bass 6M143599T (serial) year , volts , wood , features all about it , will be great 4 me .
Old 01-04-2010, 03:47 PM
Default Well....
Well, from what I read from the serial number, it is a Smith 6-String Bass - "M" Series; Made in 1999; Has the 9V pre-amp; Tiger Maple Body. Ken may have to correct or provided additional information from his records.
Old 01-04-2010, 03:51 PM
Cool More Info.....
You can find out more about this model here:
http://www.kensmithbasses.com/models...ton/bsrcrm.htm
Old 01-04-2010, 04:05 PM
thanks 4 help
Old 01-04-2010, 04:13 PM
Lightbulb but...
In 1999 when your bass was made the circuit was the 9v unit. The specs page only shows the current model specs.
Old 01-04-2010, 05:31 PM
Ken , talking about sound 9v and 18v any notable diference , its posible upgrade?
Old 01-04-2010, 08:01 PM
Lightbulb yes..
1- The build structure is different.
2- The 18v model takes 2 batteries and they drain together as one.
3- The frequency settings for the boost/cut points have 4 positions INSIDE the bass that can be 'carefully' adjusted by taking the plate off. It can be broken from misuse or careless handling as well. The 9v settings are within this switch system as well. The pre-set when we install or sell the unit is set differently from the 9v 'fixed' settings.
Old 01-04-2010, 08:17 PM
Lightbulb 4?
....3 - The frequency settings for the boost/cut points have 4 positions INSIDE the bass that can be 'carefully' adjusted by taking the plate off. It can be broken from misuse or careless handling as well....
Am I missing something here? Are you talking about the DIP Switches? If so, there are 6 positions.
Old 01-04-2010, 08:19 PM
Question Btw....
BTW - Is anything available from the manufacturer that would detail the frequency ranges for the 6 individual DIP switches?
Old 01-04-2010, 08:28 PM
Lightbulb Ahh...
Ahh, I think I see what you are saying. You must be talking about the 4 setting options within the Bass, Mid, and Treble ranges that are adjusted via the 6 DIP switches. Correct?
Old 01-04-2010, 08:34 PM
Default Here it is....
Here's the information and settings that identify "Original (9V)" and "New (18V)" settings:
Name:	Smith DIP Settings.jpg
Old 01-04-2010, 09:58 PM
Smile
thanks for help
Old 01-05-2010, 07:07 PM
Question Dip Switches
What year did the internal Dip switches become an option on KS bases? And how do they change the sound options?
Old 01-05-2010, 07:16 PM
Cool When....
I believe it was 2004 when Ken came out with the 18V pre-amp and DIP Switch opton.
Lightbulb 2004
The new 18v unit came out in 2004 on the 25th anniversary models and within that year became standard on all models. As far as sound changes, it depends on how you set it and how you eq. it. If you play with the bass flat, then it's the same. If you set it to the old 9v settings, then it's the same as well.
Old 01-05-2010, 07:19 PM
Cool How?
....And how do they change the sound options?
How? By changing the DIP Switch positions for Bass, Mid, and Treble. You'll have to experiment with these settings and let your ear make the final decision on preferred settings.
