  #24
Old 11-07-2007, 04:29 PM
Thumbs up Arrived and tested...
I tested a loose fitted KC endpin on my Hart 2 weeks ago and now I have the real thing. I had it bored for 1/2" CF which I have a cut-off from my CF endpin to glue in myself.
I tested this one (Wood pin with carbon fiber rod) on both my Gilkes and Hart Bass. The CF endpin I use is also cut short to just clear the block inside. This was by the way 1/2 the weight of the KC unit I just got. Sound difference on carpet, slightly deeper only and no noticeable difference in volume.
I bought a second one for my Martini which has a steel rod. I also have the Rod cut short. Comparing the weight between the KC and the shorter Steel rod I have is .8 ounces difference with the Steel slightly heavier.
Sound difference on the Martini? Slightly deeper on the carpet and again not much if any Volume difference.
These are 3 great master grade basses that are tweaked to the hilt already. Not much room for improvement but this new endpin idea still made all of my Basses sound slightly fuller and deeper.
One one Bass we did test 2 weeks ago, a Germanic 100 year old Bass with a long metal steel rod. This Bass had a noticeable improvement with the KC unit on a hard floor.
Conclusion! On master grade old Basses in their best condition, there is still some room for a tweak here and there. On other Basses from good to not so good, more room for improvements are always there. If you have an Endpin sticking past the Block inside your Bass after the height is adjusted, measure the overhang and cut off the excess. This is 'dead' tone sucking weight.
Bravo to KC for a great new product with custom service and fast turn around... I tip my hat!
