Old 03-27-2007, 12:41 PM
Cool It's all about....
Tim I played the SR-905 five string for about two years, the problem I had was in like kind a muddy sound and excessive hiss from either an incompatability issue with my rig at that time, a Hartke 700 watt Bass head running through Hartke 2 ten cab and one 15 cab. I had the bartolini pickups. But my question is how do you get rid of that muddy sound on the low end, how do you get to the warmth? With my ampeg all tube I have that, but if I ever go to a solid state how would you go about getting that tone?
Albert, it's all about the right equipment. You have the right bass, so, depending on your playing style, set-up, strings used, and amplification and/or pre-amp, you should be able to dial in whatever you need!
I've shared with you what I use and I stand by it and would put it up against anything.
