  #26
Old 07-11-2007, 12:19 AM
David Powell's Avatar
If I decide to reduce the radius of the board (increase the arch) there is quite a bit of thickness to work with. Essentially, I'd just be taking it off at the edges a little to match a radius guide.
It just seems that right now I have more space than I really need with G and D so I could rotate the G & D closer to the edge, bring the A to just slightly favoring the treble side of the board and that will probably do it. It's a tricky set up. I might have 3/16, but probably not on the bass side because the string heights go from 6m to 10mm, so right there I'm losing 4mm already. One thing that makes me hesitant to change anything is that the more I practice and the more the bass opens up, the easier the E string starts, so it is tempting to just leave it be and concetrate on technique. It does work, I just have to be particular with certain notes starting. Bow tension, bow speed, where the bow hits the string between the FB and bridge;- all that seems very important. I probably will not change much on this bass until I have a spare.
